Can you use the Pioneer XDJ-RR's Main Display?
I have been mapping the mini configuration on AI (on Mac) as per the Algoriddim mapping guide but I can’t get the tracks to show up on the controller screen and also can’t work out how to allocate the tracks to the channels. Have I missed a step or does anyone know how to do this? Thanks
There is no way to output information to the XDJ-RR’s main display within Algoriddim’s MIDI mapping system. This would need to be done from Algoriddim’s end within the software. Even with some of the natively supported hardware like the Pioneer XDJ-XZ, Denon Prime 4 and Denon SC6000, Algoriddim doesn’t support output to the main displays.
4 posts were split to a new topic: Mapping Channels on the Pioneer XDJ-RR
Hi @MsTee,
Thanks for posting to the community for the first time.
I have gone ahead and solved out your first question for this thread and will be moving your second question into a new thread for users to reference.
Many thanks to @Slak_Jaw for the additional help as always!
