I’m having an issue with MIDI Out in djay Pro on iPad. It worked before when I was mapping it, but now djay no longer sends MIDI messages during normal operation.
Setup
Device: iPad Pro (5th generation)
iPadOS: 27.0.1
djay Pro version: 5.6.10
Subscription: djay PRO active
Controller: Neuzeit Drop (MIDI controller)
Mode: External Mixer (Traktor Audio 10 interface)
Problem MIDI Out is configured in the mapping. When I press the “Test” button in the MIDI Out settings, the message is sent correctly. During normal operation (mostly Stem Volume), djay sends nothing.
What I verified
Using a MIDI monitor, I confirmed that the Test button produces MIDI output, while normal playback produces none.
I tried different cables.
I switched MIDI settings and reloaded the mapping (re-selected the mapping, reconnected the controller).
The issue persists after these steps.
Expected behavior MIDI Out messages should be sent whenever the mapped action or state changes during playback, as they did before.
Hi @Schlaufe, welcome to the Community. Thanks for the detailed report.
Since the Test button gets through to your MIDI monitor, the connection from djay to the Drop is working. The Test button just sends a value straight away. During playback, djay only sends MIDI Out when the mapped action itself changes. So the next step is finding out why your Stem Volume entries aren’t firing. Could you check a few things for me?
How are the stem volumes changing when nothing comes out: from the Drop’s own encoders or faders, from the iPad screen, or from a Drop snapshot?
Go to Dashboard > Settings > MIDI devices, select the Drop and reopen one of the Stem Volume entries. Is MIDI Out still ticked, and is Blend on or off?
If you map a simple button, like Play/Pause, with MIDI Out on, does the Drop receive that during playback?
It would also help a lot if you could attach your mapping file. You’ll find it in the Files app under On My iPad > djay.
In the meantime, you could put stem volume on the Drop’s faders instead of the encoders. A fader stays where you leave it, so you don’t need djay to send its position back. I hope that helps!
