Hi - I am using djay Pro 1.2.1 on a Macbook running OSX 10.11 but cannot see the airplay icon in the mixer bar. I can see all my airplay devices in iTunes but nothing in djay pro. Looked in the preferences and nothing there to configure. Am obviously missing something - can anyone point me in the right direction?
same issue here. I’ve noticed that if I set an Airplay device to be my system wide output, then I see the airplay icon in Djay, and I can only select that device. Not much what’s expected I guess…
Thanks for your question!
Please follow these steps in order to output your video via AirPlay:
- Connect your MacBook via AirPlay with your AppleTV
- Click on the AirPlay icon in your menu bar and choose “Use As Separate Display”
- Now go to vjay and click on the “TV” icon in the top right of the main vjay screen, in between the two decks.
- Choose AirPlay as an output screen and select show
I hope I was able to help you!
Best Regards,
Lukas
Thanks Lukas. Unfortunately still now working for me. I can now see my AppleTV but not the Naim MuSo - even though both devices are on AirPlay and both can be seen and used in iTunes
Any idea why this is?
Tom
