Djay Pro 5.5
Ipad 10
DDJ SR
When turning the Cue/Mix knob to the Cue position, the Cued deck gets a very very low volume. Turning it to the Mix position, the sound is very loud and clear. I mapped the SAMPLER VOL knob to use as CUE/MIX just for testing. It worked when the original CUE/MIX was in CUE position, but again the volume is very low. If the original knob is in Mix position, it doesn’t work.
I tried on Windows 11 and this problem didn’t happen, the Cue/Mix knob works perfectly as it should, so it’s not a hardware problem.
Also, the FX 1 - FX 3 on/off buttons do not work when decks 3 or 4 are selected. They always opperate on decks 1 or 3 FXs. The app does not recognize that we have changed the decks.
