Hello, i bought the djay2 and i bought an android tablet 5.1 and i dont have any sound, i see that is a common problem, can you tell me which devices of android works correctly?
Hi Enrique Villar,
could you tell us which Android tablet you are using?
i use bq aquaris m10 with android 5.1, but can you tell me which devices of android works correctly?
