Is the Mixdeck Quad able to utilize 4 channels within djay PRO for iPad?
How do you make em work, because I can’t figure it out.
Hi Ryan,
thank you for you post!
Yes the Mixdeck Quad is natively supported by djay pro for the iPad and all 4 decks are ready.
I hope this helps to explain things.
Thank you and keep it up,
