Mixon 8 Headphones, Hot Cues, Play issues
Hello all,
  • Device model : Mac M3
  • Version of operating system: Mac OS Tahoe 23.5.2
  • Version of djay: Djay Pro 5.6.3
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Reloop Mixon 8 Pro
  • Hardware firmware version: 5339
  • Please consider sharing a short video or screenshots to help clarify your question/suggestion/feedback: The fault is intermittent and has happened several times at parties. Cant capture it in the moment.
I’m having trouble mostlyy with me left deck and sometimes my right dec.
  1. Main issue- headphones stop working after working for a while. Turning the headphone volume or unplugging and plugging doesnt resolve it. The sound might return again. This is typically after a coupe of hours into the gig.
  2. Hotcues light up when they havent been set.
  3. Play button does work and have to press a few times.
  4. The crossfader doesnt trigger the crossfadeer fx intermittently and I have to manually hit play on the track for the song to play.
  5. Mic doesnt work intermittently. There’s no sound.
I can see some of these have been raised by other users as well. I want to know what is the final solutation. I have gigs coming up so I cant be without a controller for weeks on end. What is their turn around time? I bought it earlier in the year so I think I’m in the warranty period.
Thanks for your replies.
Hi @Mat1, sorry to hear this is happening with gigs coming up. Your Mixon 8 Pro firmware (5339) is already the latest version Reloop offers, so that part’s fine. djay is behind, though. 5.6.3 came out in March and the current version is 5.6.10, so please update that first.
The headphones, pads, play button, crossfader and mic are all acting up together, mostly on the left side. That makes the connection and power the first things to rule out:
  1. Use the Reloop power supply, and keep your Mac on its charger.
  2. Connect the Mixon directly to the Mac with no hub or adapter, and try a different, high-quality USB cable.
  3. Try the Mixon’s other USB port and adjust the input switches on the top panel to match.
Warranty and repairs are handled by Reloop, not Algoriddim. Their support page says warranty claims go through the dealer who sold you the unit, or Reloop’s local distributor if that dealer no longer exists. They can confirm your coverage and how long a repair takes.
A couple quick questions:
  • Can you double-check your macOS version under Apple menu > About This Mac? Tahoe is macOS 26, so 23.5.2 doesn’t quite match.
  • When it happens, does the left deck still respond to your mouse and keyboard in djay?
Before your next gig, I’d do the update and the cable changes, then give it a long test run at home. I hope that helps!
Reloop power and Mac are separate. I’m not using a hub anmore (it didnt work). I bought a high quality cable with no adaptor so the joint wont fail. I have tried other ports with the switches on the top changed but its still the same. I have now updated Djay pro. I made a mistake about the macOS. Its 26.5.2. I have to do a long test run again and hopefully capture some video footage if it happens. Thanks for the input.
@Mat1 thanks for the quick update. That rules out the power, the hub, the cable and the ports, which helps a lot.
Video is the best next step. When you do the test run:
  1. Film the controller and the djay screen together if you can, so we can see both when it happens.
  2. Write down roughly how long into the session it starts.
  3. When it starts, try the left deck with your mouse. If djay still responds but the controller doesn’t, that tells us a lot.
Hi sorry not had the time to test my Mixon 8. Will test it in the next couple of days. Thanks for the input so far!
No problem @Mat1. You’re welcome!
