Mixon 8 Pro & Djay Channel 2 Crossfading Assignment Switch
  • Device model (e.g. 2020 iPad Air 4th Gen):Dell Inspiron 14 7440
  • Version of operating system (e.g. macOS 14.4.1):Windows 11 (26H2)
  • Version of djay (e.g. 5.1.2):5.6.9
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro):Reloop Mixon 8 Pro
  • Hardware firmware version (e.g. 1.0.1):5339
  1. The Crossfader Assignment Switch for Channel 2 on my Reloop Mixon 8 Pro is not functioning properly when starting up the unit and launching djay.
    Whenever I start Djay and power on the Reloop Mixon 8 Pro, the Channel 2 A – THRU – B assignment switch appears to be disabled or unresponsive, regardless of its physical position.
    I have found that I can sometimes restore its functionality by changing settings in the Sound or MIDI tabs within Djay. However, this is inconsistent, and the switch does not always return to normal operation.
    Current Workaround:
    To get the crossfader assignments working, I have been using the following configuration:
    • Set Channel 2 to Crossfader A.
    • Set Channel 1 to Crossfader B.
    • Enable the Invert Crossfader option in the MIDI tab.
    Although this workaround allows me to use the crossfader, it is not the intended configuration and does not resolve the underlying issue with the Channel 2 assignment switch.
    I would appreciate assistance in identifying why the Channel 2 assignment switch is not responding correctly at startup and determining how to restore its normal A – THRU – B functionality consistently.
Hi @Kipp_Happ welcome to the Community!
Thanks for the detailed report. I’m pretty sure the CF ASSIGN switches on the Mixon 8 Pro aren’t wired to the crossfader. They’re MIDI controls that tell djay how to assign each deck, and a switch only sends its position to djay when you physically move it. So when djay launches, it may not know where your Channel 2 switch is sitting yet.
With djay open and the Mixon 8 Pro connected, try this:
  1. Turn Invert Crossfader off in Settings > MIDI Devices > Scratch Settings, so it doesn’t muddy the test.
  2. Flip every CF ASSIGN switch through A > THRU > B, then set each one back where you want it.
  3. Switch to 4-Deck view and check the crossfader assignment shown for each deck.
If djay ever shows the crossfader warning and you click Restore, it resets to Deck 1 left / Deck 2 right. djay then ignores the switches until you move them again, which can look a lot like a dead switch.
Let me know if Channel 2 still won’t respond after that. I hope that helps!
@Slak_Jaw
That worked perfectly! It seems that either the crossfader assignment switch on the Reloop Mixon 8 Pro is not functioning properly or the MIDI interface isn’t reading the switch correctly. Occasionally, it will select B as expected, but other times I have to manually force the parameter in Djay to get it to work.
Since this is a new Mixon 8 Pro unit, I’m going to monitor it over the next few days and see if the issue persists. If it continues, I may need to send the unit in for repair.
That’s good news @Kipp_Happ. Thanks for the follow up. If it keeps happening, one quick test will tell us whether it’s the switch or djay: flip the Channel 2 switch to B a few times while watching the 4-Deck view, then try the same thing in Serato DJ Pro, which the Mixon 8 Pro is unlocked for.
  • B registers reliably in Serato but not in djay: let us know here and I’ll pass it to our hardware team.
  • B misses in both: it’s most likely the switch itself, and since the unit is new, Reloop support is the place to go for a repair.
A short video of the switch and the 4-Deck view would help either way. I hope that helps!
