I’am using a Numark Mixtrack Platinum controller with djay pro on windows. Using the native mapping included with software, everything maps fine except for the master volume and cue volume. I am not able to control master and cue volume from the controller. I checked the midi settings for controller and do not even see an option to map these controls. Any advice or help is appreciated. thanks.
Hey tony,
we are sorry to hear that. So the controllers are unmapped? Have you updated your djay Pro lately?
Cheers,Lukas E.
