I just purchased this great contoller, however, I was disappointed to find that it wasn’t plug and play like its predecessors. Mapping has been easy at times, and a real challenge at other times, and I am wondering if there is any way to map functionality to the in-wheel displays?
My biggest challenge is getting the scratch wheels to feel right. I’ve been trying different variations of the advanced controls and am having no luck getting the proper timing from a scratch wheel stop to a cue point button. Difficult to explain, but I am wondering if there are any plans to provide a true map for this latest controller, or if I have to use Serato software instead.
Hi Jay Hodge,
first off you can find the list of natively supported controllers here: https://www.algoriddim.com/hardware
With your mapping we can give you in detail help via support@algoriddim.com.
Thank you for your post.
