I use Djay on my macbook and would like to be able to connect to multiple airplay devices.
You can connect to a single airplay device on the iPad and iPhone version which while very good doesn’t give me the flexibility I am looking for. The MacBook version doesn’t allow connection to a single airplay device never mind multiple ones.
Would be grateful if this feature could be added to the next update.
Can you play to a combination of airplay and regular audio output? It would be a great way to allow a remote speaker to play the music and not have to run 200’ of xlr cable ?
Pleased to inform you that we added support for this feature. We’re still in beta-testing phase. We’d appreciate it if you could download and test the beta version: http://community.algoriddim.com/algor…
