Multiple FX racks?
Hello everyone, I’m using a DDJ sb3, so far so good, but what if I want to add a novation launch control to my setup?
I believe it will be recognised, however I think there is a limitation for the number of effect racks, as the two are already used by the DDJ.
In short, I want to use another controller just to have more effects.
Thx!
Hi @Badix92, welcome to the Community!
  1. Please note that djay currently offers 3 independent Manual FX for each Deck plus 8 independent Instant FX Pads per deck. Adding more DJ controllers to your setup will not increase the available number of FX in djay beyond this.
  2. You can, however, connect multiple MIDI controllers to djay and use them at the same time to have hardware controls for all of the available FX.
  3. Please note that the Novation Launch control is not natively supported for djay on macOS (DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim), so you will need to MIDI map this yourself.
  4. For more info on MIDI mapping in djay on macOS, please refer to this linked FAQ: https://help.algoriddim.com/hc/en-us/articles/360014911871-How-do-I-MIDI-map-a-controller-on-djay-Pro-for-Mac
I hope that helps!
