Hi All, I use Djay pro on a Mac with a vestax vci 100.
Is it possible to connect a second Midi devices to Djay pro? I want to connect a additional AKAI LPK 25 to control the samples ?
I was about to post a similar question. Does Djay Pro 2 support using multiple midi devices?
you can connect as many controllers as possible to your Mac to work with djay Pro.
Yes, two controllers is possible. I’m currently running Djay Pro 2 on a Mac and using a Behringer CMD 2a & Wireless DJ app. The only thing I don’t yet have working is the meters on Wireless DJ, but everything else works together beautifully.
