all the musical key information in the list of songs has suddenly disappeared in djay 2.
when i load the songs onto either deck it shows the key up above as usual, but not in the songs list or playlists —when i tap sort > key it arranges the songs by key but the list of keys that used to show up on the right side is now gone… tried restarting the app and then restarting my ipad but nothing changed.
is there a fix for this?
