When I’m mixing on my serato Ddj-sx2 with the djpro software when I want to transition from one song to another my que volume blasts the volume all the way up and scares the piss out of me dose anyone know how to fix it?
Turn the cue volume down. That is how it works, it automatically switches to the other deck when moving the crossfader.
Hi larson,
Can you check which advanced audio settings you are using (Preferences > Advanced > Audio Limiter/Auto Gain)?
Also while doing a transition, the only thing you do is moving the crossfader?
Cheers,Lukas E.
