Native support for Reloop Beatmix 2
http://www.reloop.com/reloop-beatmix-2
for both mac and ios?
thanks
Does anyone know if these beatmix2 and 4 are now supported with the new Djay Pro2 ?
djay for Mac supports the original Beatmix, but not Beatmix 2. However, you can still use it with djay for Mac via “MIDI learn”.
Open “Configure…” from the “MIDI” menu to map your controller.
djay 2 for iOS does not support the Beatmix 2.
By the way, you can see the list of natively supported hardware here:
http://www.algoriddim.com/hardware
I’ll change your question into a feature request (= idea).
bump
thanks. is this likely to change?
any change, i have a beatmix 4 and can t do the mapping by myself, any help from djay pro here?
would be a great help if customer service could put up a map screenshot so it gets easier to configer djay pro with beatmix 4 reloop. ??
