I need to be able to tag the songs in key myself. All software including Mix in Key and all others get about 40% wrong most of the time. I play piano so I know what is the right key unfortunately Djay does its guessing and it’s wrong alot. Can we update the software to allow my own tagging? Also I need to be able to control my list besides just by BPM. I can do it in Recordbox but I don’t use a system like that alot. What I need is to able to tag them not only BPM (from slowest to fastest) but also in the key sequence (from A to G). That system gives me lots of control and quick glance advantage over trying to find a matching key & BPM match. If you guys can figure out how to get that done that would be a big improvement in overall speed.
- Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
