- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Is there any mappings out there for an s5? i know its a dated controller but damm there is mappings for everything besides an s5, i started doing it myself but it became very tedious and i am really looking to see if anyone out there mapped an s5. Any info would be appreciated.
small idea
download a image for the controller
open claude mark the image buttons to what you want it mapped to in DJPRO
see if claude can do that for you.
Hi @bortschellermark, welcome to the Community! Have you checked the DJ TechTools mapping site?
I don’t have Claude. I only have ChatGPT. And I’m trying to wrap my head around how that would work honestly .
Hi again @bortschellermark, here are the djay MIDI mappings for the S2 and S3. It feels like a stretch, but maybe with the help of an AI tool and the mapping that you’ve already started on the S5 they can be used to complete your mapping.
NI Traktor Kontrol S3.djayMidiMapping (175.0 KB)
NI Traktor Kontrol S2 MK3.djayMidiMapping (88.3 KB)
thanks for those! the problem is when i try to upload anything into djay pro that doesnt say s5 it says it will store them until i plug in that hardware
i tried with an s8 map because most of the main mixer controls are similar but it gave me the message that as soon as an s8 is plugged in then it will use the map.
Yeah you can’t use the native S2 or S3 mappings without those devices. My suggestion was to potentially use these in combination with your existing partial S5 mapping plus an image of the S5 layout to get an AI tool like Claude to complete your S5 mapping for you. As I said, this is probably a stretch, especially if you’re not very experienced with these AI tools.
