Neural Mix EQ should match my pads
The other night I was djing and I tabbed over to the neural mix area and decided to use the faders to fade the melody’s between 2 songs but I seen my pads don’t reflect that I faded the melody out completely or any other part of my steams when I have my pads in stem mod . It be nice for my pads to reflect which stem is completely faded out that pad should turn off and if I wanted to press the pad to bring it back on melody or bass I could and the neural mix 4 band eq would reset when I turn the stem back on with my pad . I been enjoying smooth fading my stems as of late and just realized this oversight
Hi @CrossFade1200, thanks for the feedback. Please note that Neural Mix EQs and Neural Mix Volumes (the vertical sliders shown in your screenshot) are intentionally separate ways to control NM. They are not meant to be linked together and are subtly different in how they work.
NM EQs allow you to decrease (turn left of 12 o’clock) AND boost (turn right of 12 o’clock) a Neural Mix part. NM Volumes only allow you to decrease the NM part. So they are two different ways to work with Neural Mix.
I find the best way to visually identify the effect of either control is to enable Neural Mix Tracks so you can see both controls affect the waveform. I hope that helps!
Ty I didn’t know this and I’m now going to use this mode all the time
You’re welcome @CrossFade1200. Happy to help!
