- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro 12.9 5th edition MacBook Pro m3 pro
- Version of operating system (e.g. macOS 14.4.1): latest both
- Version of djay (e.g. 5.1.2): 5.3
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Rev 5
Your question: is there a way to map the routing of bounce loop and whether it affects vocals, drums, harmonics etc. I can map fx routing but not bounce loop routing.
Hi @Dysfunk_DJ, please see below.
Yes I know that but can I map it? I can’t see where I can in the mapping area. I know you can map pads to vocals or drums but you can’t map the routing.
Currently there are only MIDI commands for Bounce Loop Drums. There are no MIDI commands for routing specifically to Vocals, Harmonics or Drums.
Another way to achieve a similar result would be to use the Looper FX. It is similar to a Bounce Loop and then you can use the FX routing MIDI commands.
Thanks I’ll look at that. Maybe the engineering team could look at having the bounce loops linked to effects routing, as that can be mapped already?
Great idea @Dysfunk_DJ. I’ve changed this topic from a Question to a Suggestion and will pass this onto the dev team. In the meantime, please vote at the top left. Thanks!
