Sorry if this is a Dumb Question (I specialize in those…). New eyes here: I’m completely new to your company, your products, and most of this stuff. I saw news of the release of Neural Mix Pro, downloaded it, ran it. Played with it for all of 5 minutes. Looks interesting, potentially exciting. I throw a song (MP3) at it. It appears to be able to “split” the recording into three component tracks: Vocals, Harmonics, Drums. For each track I can independently adjust the level up/down/muted. Very nicely done, so far…
My question: I’d like to take these tracks - particularly the “Harmonic” track (which covers a lot) and split that up into component parts: horns, strings, etc. - ideally into even finer, more discreet components: violins, lead guitar, flute, tenor sax, etc. Doesn’t necessarily have to have perfectly correct labels (violins versus violas, banjo versus guitar, etc,) but (for example) I’d like the ability to play a recording and partially (or completely) mute the lead guitar, while preserving backing other guitar accompaniment, or silencing a sax solo while independently controlling the levels (louder/softer/muted) for all other discreet tracks (accompanying strings, backing vocals, etc). I’m sure, from a technical standpoint, I can imagine this is a tall order. But that’s what I’m looking for.
Is that ability - to break down the “Harmonic” track into more discreet, separate instrument tracks - something that you get with the paid version?
Hope the above makes sense. Thanks for the help.
