Hi Djay People!
I have the MixTour Pro, and every time I load a song into a deck, the Neural Mix settings in the sotware (MacOs) are reset, even though the knobs on the mixtour are fully down.
I have to ‘capture’ all three knobs on the hardware, which is a bummer.
This feature works correctly on iOS.
Please help!
I am running current OS and djay pro software.
EDIT: OK, there are two ‘reset’ preferences, one for FX, and another for Neural Mix.
If I uncheck the option for FX reset, the neural settings are maintained. Weird, but I can work with that.
