New touchbar Macbook Pro DJPro display issues
Madam/Sir, I just installed DJPro from the app store - onto my new Macbook Pro (Macbook Pro 2016 with touch bar). I am using as follows, In macbook/system/displays I set to my macbook to two displays - scaled - more space. I then plug my external display into the macbook (via usb c to hdmi adapter). When loading in new videos (while DJPro is running), the track list in DJPro will show the same mp4 video file twice (even though there is only one occurance of the mp4 file). If i quit DJPro, then restart, all the files list correctly, but as soon as I add further files, the same happens. Perhaps there is a display issue in DJPro? My macbook pro has the Intel HD Graphics 350 1536mb and the Radeon Pro 460 4096mb cards in. Dan
Hi Daniel Forster,
thank you for your post and we are sorry to hear about your issue.
Could you please send us some screenshots of the problem, that would be very helpful.
Thank you in advance.
