Today I finally upgraded from djay 4.2.3 to djay Pro. And right off the bat I’ve run into a problem. With djay 4.2.3, it only took 1.5 minutes for my iTunes library to load into djay so I could start playing. But with djay Pro, it’s taking over 17 minutes to load the same library from the same place. Thinking it might have been a problem with the iTunes XML file, I deleted the old one and made iTunes create a new one. It still took over 17 minutes to load.
Is there any way to fix it so the library loads faster?
