djay pro doesn’t find itunes songs, playlists etc. It shows “no playlist”.
I have 2 harddrives in my mac. itunes program is on the system harddrive (SSD), the songs on an internal data harddrive. Anybody the same issue?
I have something similar. My itunes app is in the system HD and the library is on the other SSD. I have a few questions. Have you remapped your music folder in your finder to the new alternate location? In other words the one that has the notes icon does it go to you correct itunes library now? Did the playlist go away after you moved your library or was it all ready moved before you installed DJay?
our apologies for this behaviour. Could you guys tell us which Mac and operating system you are using?
That will help us to reproduce the problem.
Thank you in advance.
