Hi @Carlos_Alexandre_Cam, thanks for the follow up. Our team is still looking into this one. I will share news here when I have it. Thanks!
Hi, @Slak_Jaw ! No news from your engineers yet?
Hi @Carlos_Alexandre_Cam, thanks for the follow up. I will share news here when I have it.
I heard back from engineering and they were able to reproduce #1 as you described. They will investigate this issue further and Iāll share more news when I have it.
Regarding #2, this is expected behavior with this controller when paired with djay. Unfortunately, this hardware does not send separate MIDI messages when pressing Shift+Pad Modes so we cannot currently implement this in djay.
Hi, @Slak_Jaw . Thanks for the reply, but I think your engineers didnāt test it well.
When pressing HOT CUE, for example, NO MIDI SIGNAL IS SHOWED on the midi mapping toll. On the other side, when pressing SHIFT + HOT CUE, the midi mapping tool show an assignable midi command to be mapped.
Iād really appreciate if you contact them again. If you see the previous messagens on this topic, you will see that the SHIFT + PAD MODES are midi commands to be assigned by the mapping tool. I tested it, and another user have said the same thing.
Best regards!
Should highlight these issues on hardware list, specially #2, I was just about to get this controller, this just killed my excitement. ![]()
Thanks for the additional info and clarifications @Carlos_Alexandre_Cam. I will share this with the team.
As I said before, @hardbea7 , if we canāt work with the additional 4 pad modes, it seems weāre only dealing with a more expensive Mixtrack Platinum FX⦠![]()
And the answer from the engineering team was very dissapointing too. I looks like they didnāt even turn the controller on. How could I manage to see that the <shift+pad mode> sends a midi signal and they didnāt?
Iām almost trying to sell the unit for someone who uses Serato⦠I donāt want to use it because I prefer using the ipad, itās much more āmobileā, letā say. And I already have the DJAY PRO subscription, donāt want to change the app Iām used to .
Hi @Slak_Jaw . It has been 22 days since my last message. Does your team have anything to tell us about the use of the 2nd layer of pad modes?
Regards,
Carlos Alexandre
Hi @Carlos_Alexandre_Cam, sorry for the delayed response on this one. Thanks for continuing to push this topic. Our team is still investigating options and feasibility here. I will follow up with them again to see if they have any additional news to share. Thanks!
EDIT: They do not have any developments to share. Iāll let you know when things change.
3 posts were split to a new topic: Numark NS4FX & Platinum FX Shift Layer MIDI mapping
