I did a software update on my I Pad 2 (9.3.5) it is now not not syncing /charging when docked into the Numark iDJ Pro? Need help asap
Whats the fix?
Whats the fix?
Hey matt,
thank you for your post. Did the iPad charge with a lower iOS version?
Cheers,Lukas E.
Hey matt,
thank you for the follow up. I see, I am sorry to tell you but if the iPad is not getting recognised (-not charging) I assume you contact Numark and inform them about the issue.
Sorry that I can not help you here but this looks like an Hardware issue.
Cheers,Lukas E.
Hi Lukas,
The I Pad was working fine with the IDJ unit, has been for years, its only when I updated the OS on the iPad that it now doesn’t work? I have seen other posts on this topic by other users but not seen any answers?
Thanks for your help.
In answer to your question ‘Did the iPad charge with a lower iOS version’ in the IDJ dock…YES. And the iPad still charges outside of the IDJ dock.
Morning Lukas,
Any more info about this problem? I am playing at a club on the weekend, so need this resolved ASAP.
Thank you!
