Dear warren,
can you send me the mapping example for the mixteack edge and djay pro?
Dear warren,
ur awesome!! I bought a mixtrack quad from Numark and would be fantastic if someone show me how I could use on Djay for mac!!
Perhaps working with an ipad would be great
hi warren, this doesn’t helps. Sorry. I mapped the shift button to general>controller shift button. when i tried different options in the advanced mapping options… nothing happens. i’ve mapped everything as written above.
what can i do to use the “shift-function”? and to control the light of the shift-button?
hi, i just got this mixtrack edge a couple weeks ago thinking that i will finily get to mix again, Im a retired deejay from the 90 ́s, so i got this thing and it does ́t work!!! im correnly using a MacBook, with version 7 of virtual DJ, and file that can help me install my mixtrack edge please!!! you can send me any help to the following e-maIL addressarturomloe@yahoo.com thank you
Hi Riddim Dojo,
the Mixtrack Edge is natively supported by djay Pro. The mapping is integrated in the software, all you got to do is connecting the controller and accepting the mapping window.
Hope this is helping.
For further information please see:
http://www.algoriddim.com/hardware
