I’m trying to configure the key mapping on my Numark NS7 keyboard.
I don’t know how to configure the platter settings.
Could you please give me some hints or instructions?
Applicable model
Numark NS7
NS7 | Numark
Device model
Device Name: ASUS-TUF-A15
Processor: AMD Ryzen 7 7435HS (3.10 GHz)
Installed RAM: 16.0 GB
Graphics Card: NVIDIA GeForce RTX 4060 Laptop GPU 8 GB
Version of operating system
Edition: Windows 11 Home
Version: 25H2
OS Build: 26200.8246
Windows Experience Pack: 1000.26100.297.0
Version of djay 5.6.4
Hi @DJKENTA, can you please provide more details about your issue? Are you creating a custom MIDI mapping for the NS7 from scratch? Is it just the platter mapping you’re having trouble with?
Hello.
Thank you for your reply.
I’m trying to create key mappings from scratch.
By “key mappings” do you mean musical key? Like “Key Match”? Sorry, it’s still unclear what your issue is. Maybe you can share a short video or screenshot to help clarify. Thanks.
The biggest problem is the platter settings.
I don’t have a screenshot right now.
I’d really like to know how to control the motor platter on the NS7.
Okay, thanks for clarifying. Please refer to this section from the Windows djay User Manual and let me know if that helps.
For more general MIDI Mapping instructions, you can start here in the User Manual:
Thanks for the information.
I’ll try it.
I’ll report the results.
No matter which way you turn it, it only moves in one direction.
Also, is it impossible to drive the motor using MIDI control?
Thanks for the follow up and video @DJKENTA. There are no additional MIDI commands for motorized platters. I suspect the NS7 requires specialized drivers and commands to properly control the motorized platters. This is likely the reason why we do not support this hardware. Sorry I couldn’t be of more help on this one.
Unfortunately, I’ll have to give up on using DJAYPRO with this NS7.
Thank you.
Okay @DJKENTA. You’re welcome.
