I have a numbered play order on my iTunes playlists. How do I get to see a numbered play order in djay?
Bump- this would be helpfull -
Sorry, not quite sure what you mean. Do you mean the track number? You can enable this under Library > View Options > Track Number.
Generally speaking, djay takes the playlist exactly as it is in iTunes.
Can you please upload a screenshot of what you mean? Thanks!
Oh OK, thanks. This is apparently not the same as track number. I’ll change your question into an “idea”.
No, not Track Number.
I mean the sequential Numbered Play Order which is automatically generated on the right hand side of the music track when using iTunes.
Oops!
I meant LEFT hand side, not right as indicated above.
