Hiya,
I bought Djay 2 just now because I figure they will never add spotify integration to the first version now and that is something I am waiting for.
I have found that they have changed the way the volume sliders work, you used to be able to simply tap the volume slider for it to completely cut out the sound of the deck that that slider relates to, this was excellent, but seems to have changed to something very different now. Is there a way for me to change back?
Also will spotify Integration be coming any time soon?
Also you need to add Djay too to the list of “related products” on these forums.
Thanks,
DJ
