Is it possible to install de dj for Mac in a second computer?
If you bought djay via the Mac App Store, then you can just open the App Store on your other Mac and go to “Purchases” to download djay.
You can install on your other Macs too but you’re not allowed to use djay on multiple Macs simultaneously. Click on “djay” on the menu bar and select “De-activate” to obtain your license key.
