OneLibrary - Add "Grouping" field to Export
Using djay on both devices, I’m using OneLibrary to export playlists created on one laptop to another. It works great with the caveat being that I use the “Grouping” field for specific notes (which I know is native to djay so that’s why I use it) but unfortunately OneLibrary does not export that field.
Considering there currently is no playlist sync, I’m wondering if this could be part of a playlist’s exportable info for those of us who only play inside the djay ecosystem (laptops, iPads, iPhones etc.), with Rekordbox and others simply ignoring the field. Would save a ton of time and work.
Thx.
Hi @Reign712, thanks for the suggestion. I’ll share this with the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
