OneLibrary duplicate files?
So this is exactly what is happening
I copied a playlists the 1st time on my phone,
then made some changes on rekordbox added some tracks changed title etc , then again I copied the one lib usb to the phone
Now the my collection playlists on my iphone shows
tracks before I made changes , I mean the they are not getting updated ( the titles of the Trk) when I copy them. The additional treks added to the playlists are showing
I have tried deleting all playlists and tracks even from file explorer in the djay folder deleted the bkup library files still nothing is getting updated
Then. I disabled the icloud sync thinking may b that is creating some problem still no luck
I have even tried reinstalling the app with fresh settings
Okay, thanks for the additional info
My one lib usb collection is 16gb , so with the current setup if I add new tracks I delete collection from djay on my ios and then load my usb again. It works fine. So I assume the data of djay app should be around the 16 Gb mark.
Now I decided to update my phone to ios 27 beta, and I was unable to as my phone shows I only have 6gb left , dj app is showing 86gb in data. Something is not right here. Even after I delete my collection and load it again the data is so large.
The solution is now I have delete tha app then install it again and then load my one lib usb
This pic is after deleting the app loading the usb.
Some better way to do this ?
Hi @DjSasha_DelhiDevils, you probably had several backups of your djayMediaLibrary database in the djay>User Data>Backups folder. In the future, you could manually remove these instead of deleting the app.
Have tried deleting the backup files , still in the iphone app storage it’s 17gb even after clearing all data and collection. Any way to fix this?
Are you using the Beatport or Beatsource streaming service with an Offline Locker?
No
Only my usb one lib
Thanks for confirming @DjSasha_DelhiDevils. You could try a fresh djay installation by deleting the app and redownloading. I suggest that you backup your djay Media Library database and any custom MIDI mappings, then uninstall djay, reboot your device, and reinstall the latest version of djay.
You can find the files above in the following locations: iOS: using the Files App, navigate to Locations->On My iPhone/iPad->djay->User Data
macOS: How to find your djay data and move it to a new device | Algoriddim Support
Windows: How to find your djay data and move it to a new device | Algoriddim Support
Yes I tried that also, still after deleting the music library to re import my updated usb the app app data is same
I’m not sure what else to suggest @DjSasha_DelhiDevils
