Has anyone successfully exported from one library on a usb from DJayPro to XDJ-RX3 Version 1.19?
Hi @StarStruk_DJ, AlphaTheta does not yet support the RX3 with OneLibrary.
Currently only the CDJ-3000X, XDJ-AZ, OPUS QUAD and OMNIS DUO are supported.
I exported my djaypro library playlists as One Library to a USB, imported the playlists from the USB into Rekordbox software and finally exported the playlists to the USB as normal playlists / non-„one library“.
As a result, I have two folders on my USB, one normal and one „One Library“ format.
When plugged into my RX3 I was able to play the playlists/tracks from the USB.
Not sure if that is what you was looking for, though ![]()
Thanks for sharing @turbopussy
Thank you
