OneLibrary Sort Playlists A-Z
Just getting started with OneLibrary, it doesn’t look like there is any option to sort playlists in the library. I would like to do this alphabetically, is this possible? I am on MacOS.
Hi @MattBrinks, welcome to the Community! Currently, playlist sorting is not supported with OneLibrary. However, you can drag-and-drop to reorder the playlists manually. I hope that helps!
I was able to open it in Rekordbox and sort it that way. Might be a good feature to add someday!
Great! Thanks for sharing @MattBrinks
