How do you use open in?
Hi Dana,
Click on the recording button to access the list of recorded mixes. Now, if you select a track and tap “Open In…”, all apps that are installed on your iPad/iPhone which support AIFC audio files will be listed.
On the other hand, if another app supports “Open In” as well, you will be able to choose djay if it’s a supported audio file (e.g. mp3, aac).
When I use “open in” from external application. Can I save or use that imported songs later without using “open in” again? Thanks
When I use “open in” from external application. Can I save or use that imported songs later without using “open in” again? Also, djay caches the song everytime I use open it. Say I open the same song 2 times, app caches it 2 times taking a lot of room. Is there a limit also on the amount of memory used to cache these open in songs? Thanks
