Personalized Screen Layout Option
Hello,
Can there be a check-off list of options that you want displayed and those you don’t want displayed, and AI will generate the screen? This personalized look can add to the efficiency of using iOS with smaller controllers. For instance if I don’t want jog wheels, but I want faders and loop buttons larger. Or I want a permanent Stem row. Just something to think about.
Thanks for the suggestion @E_Flem. I’ve passed it onto our devs for consideration. Please remember to vote. Thanks!
