Pickup mode is enabled for the 3 knobs (high/mid/low) on the Hercules DJControl Mix Ultra. These knobs double as Neural Mix stem controls when the center Neural Mix button is pressed.
Steps to reproduce:
1. In Neural Mix mode, turn a knob down to mute/lower a stem (e.g. vocals) on a track
2. Switch out of Neural Mix mode (e.g. adjust the EQ high on that same knob)
3. Switch back to Neural Mix mode
4. Slightly move the knob
Expected: pickup mode should require moving the knob back through the last set stem value before it responds.
Actual: the stem instantly jumps to the knob’s current physical position (i.e. the set EQ value), ignoring pickup mode.
Pickup mode works correctly for EQ-to-EQ switching, but not when switching between EQ and Neural Mix on the same physical knob.
Device: iPhone 17
djay Pro subscription
Controller: Hercules DJControl Mix Ultra
