Pioneer DDJ1000/1000SRT
YOUR QUESTION:
Quick question,
Are the Pioneer DDJ1000/1000SRT compatible with Dj Pro using IOS?
They aren’t listed which probably answers my question but wanted to know if they can be manually midi mapped.
Hi @maurizio_T, neither of these are natively supported on iOS. Unfortunately, I’m pretty sure that neither the DDJ-1000 or the DDJ-1000SRT is USB class-compliant. Both need Pioneer’s driver to run on a Mac, and iOS doesn’t allow drivers to be installed, so an iPad or iPhone can’t communicate with them properly. As such, a custom mapping won’t fix it. MIDI Learn lets you map any controller djay can already see, but it can’t make up for missing class compliance. Even if some controls did respond, the built-in sound card still wouldn’t be available for your main and headphone outputs.
Thank you Slak,
I remember that being the case but wasn’t sure if there had been a recent update that may have made it possible..
Just another question if you or anyone knows,
Is there a Pioneer controller that has a screen that can be used with IOS?
I’m trying to see if I can Dj back to back with another Dj that uses his USB with Pioneer Rekordbox whilst I use Djay Pro with my iPad on the same controller.
In the past I have just brought my Denon Go and tapped into one of the Pioneer controller channels but was wondering if there was a way around so that I didn’t have to do this for the future.
Thanks in advance
You’re welcome @maurizio_T. Currently there aren’t any Pioneer controllers with screens, where the screens work with djay on iOS. The controllers work, but the screens aren’t supported so you need to use the iPad screen.
Thanks Slak, What I meant by screens is that I would be using my ipad with Djay Pro connected to the Pioneer controller and my colleague would use his USB stick like he would normally use it as a Pioneer/Rekordbox format, This way we could both dj seamlessly from the same controller back to back..
Is this possible with any Pioneer controller out there without the use of a laptop?
I can do this with the Denon Prime Go but the major hiccup being that when you switch from using Djay Pro software using the Engine software, The music stops and is interrupted for about 30sec, and obviously this is using Engine software rather than Rekordbox which is what I am trying to achieve
You’re welcome @maurizio_T. Thanks for clarifying. That makes a lot more sense now.
The closest match I can point you to is the AlphaTheta XDJ-AZ. It’s officially supported by djay on iOS, and it plays rekordbox USB sticks standalone. According to AlphaTheta’s manual, software control is switched on per deck. In theory, that means one deck could run djay from your iPad while your colleague plays from his USB on another, so you could hand over without the music stopping.
To be upfront, I haven’t been able to confirm that mixed setup with djay on iOS yet, so I’d test it before buying or taking it to a gig. I hope that helps!
The DDJ 1000 is not officially supported on iOS, but it’s compatible. Checked it myself. If you connect it to iPad/iPhone the midi map is ready and you can play music through the device speakers. If you want to use external speakers and headphones you need a 4 out external audio interface, there are cheaper and more expensive options I can suggest if needed. As for the B2B set, a friend who comes from Rekordbox can create a One Library USB drive and connect it to the iPad.
Thanks for sharing @Pg_Gee
Thanks for the info, much appreciated
