Please disable update while using the app
Bonjour,
This morning I had an issue while playing my set : I was connected and The DjayPro application updates, so this creates slow and cut during my set. I thought there was a “security” avoiding update while playing…
Isn’t there an Android system (OS) setting for that?
Simple deactivate automatic app updates - problem solved. :wink: Regardless of the specific circumstances, this is generally a good idea.
Thanks Chris, it is done now. The kind of things that happens only once :slight_smile:
I have another question (when it regards Android, it is for my boyfriend
Yannfillatre@yahoo.fr, not for my windows account), so regarding the use of
Android, we noticed that when we use the Djay library for a mix, around
once every hour, the app freeze. We emptied the memory cache, we closed all
other apps and we have a xiami with 6Go. Is it normal and we have to adapt
to this max 1 hour or is there something to do to improve this situation ?
Thanks in advance for your support, really appreciate it
Hi @Christine_Dm, please make a new Bug Report topic for this issue and answer all the questions in the topic template. Thanks!
