Pre cue "headphone sign" turns off when I crossfade completely.
I have a problem. I like to mix with both “Pre Cueing outputs” on all the time. When I use the crossfader and I fade completely to one of the sides, the headphone sign (Pre cue) turns off by itself. It wasn’t like this before.
Can someone tell me how I can fix this?
Yes, it was like this before. When you crossfade to the other player, it automatically turns off the cue and turns on the opposite player cue.
Hi Marc-Andre Petelle,
thank you for your mail. Can you tell us which version and device and controller you are using?
