I am running DJPRO for Windows with Bose Companion 5 speakers. I could use the best process to precue using headphones??? Sorry. new to this! Thanks, folks!
Hey William Kraemer,
thank you for your post. Only with the Bose Companion 5 it is not possible to Pre Cue. You need a controller or another 4 channel device which you can use to send the Master Output to your Bose Companion Speakers.
Cheers,Lukas E.
