Pre cueing
Hi I am quite now to this. I am trying to split deck 1 and deck 2 in order to precue. However when I set it up with splitter out the headphone jack from my mac, and I fade one track into the other track, I am still left with some residual sound from the previous deck… Can anyone help me out? thanks
Hey Laurie RS,
thank you for your post.
Can you tell me which Splitter Cable you are using?
Cheers,Lukas E.
Hi
I’ve tried two different splitter cables, if you want the exact model I can try to find it for you. They are not particularly good ones though. Does it have to be a specific one?
Use the griffin cables bit pricey but shop around
