Exactly as it says on the tin. Pressing the button that sorts the library by BPM CAN (emphasis on can, I’ve seen it happen in about 10% of instances when I’ve tried to reproduce it) cause djay to freeze if the button is pressed twice in a quick succession. Not really sure what the cause of is is, I can send logs if you want (but not sure how)
Cheers
