Been using using DJay Pro on MacBook for a few months and jus decided to get this simple controller as it should make things easier. All seems pretty simple to use except I can’t find how to preview a track in playlist before loading it using controller. does anyone know if the can be done or do I need to still use mouse or trackpa to do this? Thanks
Hi Andy,
are you asking for a midi button on your controller in order to preview in your library?
Thank your for the post.
