Hi @SIMSU_84,
The best place to start is the supported controllers list on our DJ Gear page. Any model marked with an asterisk has a footnote listing exactly which features aren’t supported, so you can compare devices side by side. DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim
Since you’re on macOS, some of those footnotes won’t affect you. For example, the only limitations listed for the DDJ-FLX10 and DDJ-REV7 are jog wheel screens on iOS (plus DVS on Windows Arm for the FLX10).
For an all-in-one, the RANE SYSTEM ONE got native djay integration in djay 5.6.9, including display support. It needs Engine OS 5.2.0 on the unit. Thanks for the tip @STU-C! One correction on the PRIME 4 G2: djay support has been announced, but it isn’t available yet.
It’s also worth knowing that every device runs djay in either Internal or External mixer mode. The hardware determines which one, and djay sets it automatically for supported gear. In Internal mode, djay does the mixing and sends one stereo mix out, so djay’s filter, FX, Automix, recording and Booth output all work as usual. In External mode, each deck goes out on its own channel and the hardware mixer does the mixing. That means the device’s own onboard FX shape the sound, but Automix, djay’s internal recording, crossfader position and library preview aren’t available. You can see which mode you’re in under Settings > Devices. If any of those features matter to you, ask here which mode a model uses before you buy. Internal and External mixer mode | Algoriddim Support
Regarding the filter, n djay, currently the Filter knob always acts as a filter. On hardware with Sound Color FX-style knobs, the selected effect is added on top of the filter instead of replacing it. There’s an open suggestion for this: Improve djay Pro VCF Filter
Service and repair in Europe are handled by each manufacturer, so it’s worth checking with their EU distributor. Once you’ve narrowed it down to two or three models, post them here and we can go through how each one works in djay. I hope that helps!
