Problem transfering djay2 recordings onto ipad
I used to be able to view my recordings on iTunes apps as you mentioned buy now they don’t show up… ? From one day to the other I cant see or extract my recordings from the djay2 recordings though they show in the “recordings” I just cant get them out to iTunes… Please help.
Hey there,
that sounds odd, can you send us a mail with your iOS version, djay version and the iPad you are using via support@algoriddim.com? Also please copy the issue text :slight_smile:
