Perfect sync doesn’t always work? Using mix track platinum, will have a song playing, cue the next. At the point where i want to start bringing it in, I’ll press play then both sync buttons. Sometimes this works perfectly, other times it does nothing at all and only the sync button of the song I’m playing in will light up. The songs I’m syncing are quite similar with c.126pbm. Help! Am I doing something wrong? How do I get the sort of perfect sync that is on the iPad version of Djay 2. Thks xx
Hi Edward,
are you working with the Automix will using djay Pro 2?
