I just got a RANE Performer and hooked it up with djay Pro. I noticed two things and wanted to check if anyone else has experienced the same.
First, the Noise FX does not seem to work independently (combination of Filter and Noise) like it does well in Serato. It only triggers when the track is playing.
Second, I’m noticing some drift when using a 4-beat loop with Sync disabled, but only when the motor is enabled. When I disable the motor, the drift does not happen. I also do not experience this issue with my DDJ-REV7.
Has anyone else noticed this behavior with the Performer and djay Pro?
I’m using :
Device Model : Macbook M1 Pro 2021
Version of operating system : Macos Tahoe 26.5
Version of djay : 5.6.4
Hardware/controllers used : Rane Performer
Hardware Firmware Version: 1.3
Hi @ThunderZzz, When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
I’m also experiencing this drift issue, but mine occurs on all DJ controllers.
I’m using a 2015 MacBook Pro with a Core i7 processor and 16GB of RAM.
DJAY Pro version 5.6.4
And even then, the dynamic BPM function doesn’t allow you to create like in Serato… here it only allows you to detect areas of variation, yet if it allowed creation, it would be incredible for creativity.
Device Model : Macbook M1 Pro 2021 16Gb of ram
Thanks for the setup details @ThunderZzz. Can you please share a short video of the noise/filter issue and the motor drift issue? I want to make sure they are accurately communicated to our engineering team. Thanks!
Thanks for the video @ThunderZzz. This clarifies things. I have passed this onto our engineering team to see if they can reproduce it on their setup and offer and suggestions. I’ll report back when I have news. Thanks!
The looping/drift issue has already been shared in another channel so let’s focus this one on the FX/Filter issue.
